#23154 01/27/06 02:01 AM
ggwc43 Offline OP
can someone tell me where i can find spec,s on a 1933chev. 3 window coupe frame ? thanks ggwc43.
#23155 01/27/06 09:26 AM
standard or master?....joe
1931 Sedan Delivery 31570
1968 Z/28 Camaro
1969 SS 396 Camaro
#23156 01/27/06 06:35 PM
Hey ggwc43,
Let's get specific here. Come on , give it up, what is the JOB NO./ Style NO. ???Bill/KC Wood MFG
All the best, Bill
#23157 01/28/06 09:12 PM
ggwc43 Offline OP
joe; i don't know if it is a std. or master. i have a full fendered 3 window coupe without a frame and i need the de mentions so i will be able to measure one if i get a lead on/ or the opretunity to buy one. thanks bill, but i can't give up what i don 't know
#23158 01/28/06 09:39 PM
If the job number is on the cowl post it so we can help. If the cowl tag is gone, count the major rear fender bolts. Are there 6 or 7? Another way to tell is if the trunk lid is steel under side or wood..Joe
1968 Z/28 Camaro
1969 SS 396 Camaro
#23159 01/28/06 09:50 PM
ggwc43
I'm looking for the same thing. I have a glass 3 window. ( I know, but the price was too good) I found what I was told to be a 32-33 frame but have no way of knowing. I was told that '32 all had 109" wheelbase and the '33 had 110" or 107" so I'm not sure how that frame could be '32-'33.
Jim
#23160 01/28/06 10:02 PM
I'm not aware of any 33 3 windows made in fiberglass, only 34/35 std....joe
1968 Z/28 Camaro
1969 SS 396 Camaro
#23161 01/28/06 10:30 PM
ggwc43 Offline OP
jiaccino superior glass works Mulino,or. makes a 34 coupe phone 5038299634 they also build frames .your wheel base should be 107 stk. i need to know the width frt & rear.
#23162 01/28/06 11:48 PM
The 1932 frame is 150 13/32" long from front spring eye to rear spring eye.The 1933 master frame is 151 7/8"....I don't have figures on 1933 Std. but would be shorter.The 1933 Std frame is 22 7/8" wide at the front frame horns and 41 7/8 at the rear.The 1934 Std is 28 1/8" front and 43 1/2 rear.
#23163 01/29/06 12:19 AM
ggwc43 Offline OP
thanks chevgene your info will relly help ggwc43
#23164 01/29/06 12:35 AM
ggwc43 Offline OP
JDTravler : where in missouri do you live? ggwc43
#23165 01/29/06 09:10 PM
ggwc43: Cape Fair area. Call it home but haven't been there for much of any time lately. Temporarily set up shop in Brazil for the time being!
I'll get a picture of the glass 3 window. It's made by Mufacar out of Brazil!
Jim
Jim
#23166 01/29/06 11:47 PM
ggwc43 Offline OP
jdTravler good luck w/your coupe. thanks for the response. ever in area of kearney / k.c. let me know through this site. ggwc43
#23167 01/29/06 11:54 PM
+ggwc43...back on about the 27th I Emailed you some pictures of frames...Check you spam or??? may have landed there.
#23168 01/30/06 09:24 PM
ggwc43 Offline OP
thanks chevgene i will try to retreve ggwc43
#23169 02/07/06 12:46 AM
To all,
I have a 33 Master 5 window coupe, that I am building into a streetrod (perish the thought).
I have owned a 57 convertible, 56 convertible, a 55 210, 2, 56 3100 pickups.
This one I'm going the streetrod route.
I need to find a good home for the stock chassis parts: front axle
front springs
rear springs
rear end/ torque tube
backing plates/brakes/drums
hydraulic shocks
steering column/etc
There is a possibility that I will use a Roadster Shop chassis, which will make my original chassis available.
I also have some NOS parts for 55-57+ pickup parts available, for restorers.
Anyone interested, please respond>
Michael!!!
Michael
