37ryan Offline OP
i have an all original 37 master 2 dr sedan and need the following dimensions: 1)the horizontal distance between the bell hsg engine and transmission mounting faces, 2)the horizontal distance between the bell hsg/transmission mounting face and the rear transmission mounting bolts, and 3) the horizontal distance between the bell hsg/transmission mounting face and the centerline of the shift lever as it comes out of the transmission case. Hoping someone has a disassembled unit to make it easy to get these dims. Thanks in advance
I think I can help,have engine and tran on the floor. Why would you want this info? I think Tiny has one out also.
Randy
1. 6 3/4" 2. 9 3/8" 3. 3" Hope this helps with your project.
Randy
Ryan, I may not be correct for your 37 as I measured a 38/39.
The guts of the 38 bell housing are different from 37. Will check my 37 and let you know if different.
Randy
Ryan, a bit difficult on my back under the 37 but I think it is the same as the 38.
Randy
