#230842 01/14/12 11:15 AM
Hi
I am replacing the wiring to my 1931 pickup headlamps. I have removed the rim and lense on the headlight and the cork gasket but am having trouble removing the reflector. Is there anything else holding the reflector in the headlamp body. Thank you in advance for any replies.
Lee Shappy
Someone's opinion of you does not have to become your reality.
There is a wiring pigtail between the reflector and headlight body.
JYD,
Does the pigtail hold the reflector in place. I can't get the reflector to move away from the headlight enclosure. Maybe rust is holding it in place.
Regards,
Lee Shappy
No. The reflector should pop right out so that the pigtail can be removed.
JYD
I found the answer. It was just held in place by corrosion which had built up between the reflector and the housing. Thanks for the reply.
regards,
Lee Shappy
You bet and have fun with your project!
