I'm finally getting to work on my 34 Master 2-dr sheet metal. After straightening, patching and filling, I'm doing a test assembly to see how the major pieces line up. My problem today is that I can't remember how the parts for the rear spare tire carrier go together. I took it apart in 1980 and the few pictures I took don't show this assembly. Specifically, does the cast iron spacer go between the frame and the apron? What bolts/nuts are used and which direction do they go? Any help or diagrams would be greatly appreciated.
