Posts: 74 |
Hi Gang, My '30 Chevy has Champion spark plugs that are in two parts: One bit that screws into the head, carrying the ground (earth) electrode, and a second bit that screws into it carrying the insulator and central electrode. Both parts are pressure-sealed by Cu washers. On the back floor, I found another set of <used> plugs that are of one-piece design. Originality is not my quest at this point, especially for normal-wear components, but what is the 'best' replacement plug? Comments appreciated.
Rick
Posts: 130 |
Posts: 11,162 |
JYD , Who sells those AC plugs and are they $11.00 each? OOPS! sorry wrong model year, I need plugs for a '28 I have a good looking new Champion plug for $4, since D.B . never sent those A/C's to my favorite charity: MrMack's Ministry LLD. Inc. La De Dah. AKA Brother Chevy Loves' Starvation Show!  :love:
The correct spark plug for the 1928 is the AC 78S and only the OLD version and not the new. The original plug was a 3/4 reach and the new one is only 1/2. So look for the old ones which are usually available at swap meets.
Posts: 11,162 |
I guess that is why the guy sold me the Champion plugs he said something about them having the proper reach and that the A/C replacement didn't! ( and he usually knows what he is talking about, he is a native Texan) It sure runs good with them. I gapped them to almost 40 thousandths
Posts: 2,299 Likes: 8
Posts: 2,299 Likes: 8 |
Ray, What about the AC 78 or 76 spark plugs for 4cyl. Chevy's
Hi chevy b, Suggest you go to the 12-28 department and read the comments by pre25chevy4. :p As to the AC 78 and 76 spark plugs, how to read a plug is in order. 1. AC-Delco of course specifies the manufacturer of the plug. 2. The 7 indicated that the plug is 7/8 thread size. (That is compatable with the Chevrolet 4-banger) 3. The 8 or 6 (second digit) indicates the heat range on a scale of 0=cold to 9=Hot. The AC-Delco spark plug catalog lists the AC C77 as the recommended plug for the Chevrolet 4-banger all years. Now we have a new digit interjected and that is the prefix letter C. C=commercial :p However, the key to the plugs used in the 4 cylinder cars is they must, a) have 7/8 threads, b)have 3/4 reach or longer, and c) be at or near the desired heat range. (Which is about an 8) Why do we need a plug with 3/4 or better reach? Because the threads are much deeper in the heads of the 4 cylinder cars. If a plug of only 1/2 inch reach is used for any period of time the unused section of threads will be damaged and any attempt to install a longer reach plug will require the threads to be "chased". What is not mentioned here is other brands of plugs. Any brand will work that meets the specifications above.
Posts: 11,162 |
JYD, there is a lot to be said for that "Tech Advisor" ....If it WON'T screw in it may not work too well! Oh something I have learned here ,sometimes it is better to only give a Generic or partial answer, and let the question asker do the research and work. makes better troops out of them.
Posts: 291 |
I just wanted to chime in about "If it will screw in, it will work." That is a fine statement if you're talking shorter a reach, but watch out if the reach is too long.
Dan.
Together we can do anything. The impossible just takes longer.
Posts: 1,739 Likes: 2
Posts: 1,739 Likes: 2 |
On the topic of spark plugs my original Canadian owners manual states AC Metric 140 spark plugs for 1929 Canadian models. Where can I find those??????
Posts: 74 |
According to ones who <might> know, the AC Delco part number, C86 means:
C = Commercial 8 = 18 millimeter 6 = 6 on the heat range scale, just above average (5).
No indication as to reach.
