Hello all,
Since getting the '47 Chevy Fleetline running & driving again we've been sorting out little nagging problems. The lack of turn signals has now come up on the 'to-do' list and I can't figure out what to do next. I'm hoping some of the experts here can chime in with suggestions on what to do other than pull out my hair, which I am considering
Here's what we've done: All exterior lights work like they're supposed to, including parking & tail lights & brake lights. Bulbs have all been replaced with proper 6 volt type and wattage. All grounds have been cleaned, all housings & contacts have been checked & cleaned. The car is using a Signal Stat universal signal unit and wiring has been checked.
Here's what happens: Turn signals will light up but not flash. Flasher unit was replaced with NOS Signal Stat original in the box for a 6v system. Plugged it in and it does the same thing. Lights light up, but will not flash.
Could it be a bad original and NOS flasher? I surely wouldn't think so, but what do you think? What could I try next? Should I use another aftermarket flasher and see what happens? Rip it all out and try a new signal kit? Am I missing something simple here?
Thanks as always for the advice!
