#229826 01/06/12 09:33 PM
i am getting ready to put the instrument cluster back in my 32 and a genius thought came up. should i have the speedo lubed before i do that? I grew up with a shop on the corner that did that work, the guy sat in the window where we could watch. no way in hades i am going into that thing myself.
they don't make em like they usedta
R u wanting it to be calibrated ? I am told the magnets get tired and don't read properly.
I ran mine (31) with a drill. Ut worked and I have not lubed it and have driven it about 4000 miles without problem. It needs to be calibrated because the mileage is off.
BUY AMERICAN KEEP AMERICANS WORKING
thanks,i just wonder if there are bearings that should be lubed after 80 years
The speedometer cable should be lubed and so should the speedometer head itself. The worm gear and the driven gears inside of the speedometer should be lubricated with a special speedometer lube. Also the shaft inside of the speedometer has a small brass cup that can be removed and inside of the housing under the cup is a felt wick. A few drops of oil should be placed on the felt wick also.
The small bearing in the main shaft that supports the speed cup (needle shaft)will need to be lubed also. It is probably the most neglected part of a speedo.
Mileage won't be changed by weak magnetic force. Only the speed will show slow.
They aren't that hard to take apart and clean, for relubing. Just be careful when removing the needle and the speed cup.
Any man that thinks he is too old to learn something new probably always was
i sent you a post
Got your PM and I just sent you a reply.
