Posts: 22 |
Dear Chevy Specialist, I have a quistion: who can tell me the year of making a spare engine with these following numbered: GM 8338101.6 Eng. Nr 519236. The oil cap is on the right hand side. Thank all of you for your help.Happy New Year. Greetings Cor Hulkenberg The Netherlands
The numbers do not compare directly with any US GM numbers .Teh 1938 had a casting number of 838710...The casting numbers are raised. The 1937 had the engine number stamped into a flat area next to the fuel pump.The US numbers ran from #1 thru 1187821.
The stamped engine number was behind the distributor from 1938 and up.The 1937-38 had more than one bolt hole next to the distributor to hold down the dist.The 1939 and up only one.The 1937-39 has a cast round oil (about 3 inches long ) distributor valve on the left side of the engine - down behind the exhaust pipe.The 1940 and up has a oval tin plate with three screws.The 1937-40 head has shorter head bolts on the left side.The head is raised in that area on the 1941 and up so they will have all longer head bolts.The 1941-48 head will have the small 10MM thread spark plugs.The other years 14 MM.
Posts: 22 |
Dear Chevgene, Thanks for your explanation, I unterstand. When you will, you can see the engine block on www.PreWarParts.com , Parts for Sale. Thanks again for your help, Nice Sunday. Cor Hulkenberg, The Netherlands.
A picture of the left side of the engine would be more helpful.
Its a 1937 engine.Would fit a 1938 and 1939 but would not be 100% correct. The casting number is mis-typed.Its 838101 (for 1937).
Posts: 22 |
Dear Chevgene,
GREAT ! You are a Genie ! ! It is a pitty that is not a engine for my eage Std 1935.
With kind regards, Cor Hulkenberg The Netherlands
