Good day, I have an old artillery wheel that came with my 1941 coupe project. I have someone who wants it, so I did some searching to try and figure out what it was and what it's worth. After a few months I have only found one other like it, see link below
http://www.ebay.com/itm/15-CHEVY-AR...ries&vxp=mtr&hash=item4ab261b319I've seen many artillery wheels, but this one is 15" and it has a tire mounted on it. I can't tell if it's 5 or 5.5" wide with the tire on it...and I don't know if it's for a chevy car or truck. Markings as follows: around one bolt hole it has "G" stamped on one side of the hole and "M" stamped on the other, can read a "5" beside the tire stem but can't clearly see if there is anything more there...and it has an odd little hole drilled beside one lug nut which I thought was someone's messing around with it until this one on eBay showed the same. Can anyone comment? Is it really worth what this eBay one is asking???
