Posts: 40 |
My regulator has been amp meter has ben acting funny,whith the headlights off ,if I rev the engine it will go almost to full charge,and when I put head lights on it goes to 0. I put an nos delco voltage# 1118301 in I get nothing. I notice that the reg. I took out mounts directely to the firewall,no rubber grouments. the nos regulator,mounts whith rubber gromutes,no grounding,to firewall.Does anyone know which is correct? It is a 1952 chevy,6 volt as factory built,no changes.Thanks Ed
Posts: 3,136 |
Lets start with the new regulator...because the old one sounds kinda normal...there is no needle movement at all with the new regulator ?
Posts: 3,136 |
...Be da man and run that simple procedure by us one more time...thanks
Posts: 3,136 |
...You Da Man...! Thanks J.D. I'll write that down in my note book for further reference...
1118301 is NOT the correct regulator for a 1952. The 1952 used the short generator that has no brush cover band. the correct reg. for a 1952 is a 1118721 or 1118725.....unless a og 1940-1951 generator has been installed.
Posts: 40 |
Thanks all for replying,I have the short genarotor,whithno band.I did polarizs it,But my real question is should the regulator be grounded to the body directly.Ed
Yes, the regulator is to be grounded. Usually, one of the mounting holes has a strap attached that grounds with the mounting screw.
Posts: 3,136 |
Do I have to polarize after installing new wires from generator to regulator ? My wires are cracked and exposed and need replacing...Thanks , Kevin
