Posts: 136 |
Hi, I have a 1930 Chevy 3 window coupe What is the bracket or the hanger called that holds the muffler itself to the frame? It is not the Exhaust pipe muffler hanger as seen in The Filling Station Part # AF-139.
Where can I get one?
Thanks Steven STPJEP@YAHOO.COM
Posts: 36 |
If you have the bracket on the frame, you may just need the strap that attaches the muffler to the bracket. The strap is 1" wide and 12 11/16" long, and both ends are hooked. Chevy part number is 344194. Sorry, I can't tell you who sells the strap, but try Gary Wallace, (314) 293-1991.
Don H
I made my strap out of stainless steel. One end of the stap is hooked onto the frame muffler bracket and the other end of the strap is attached to a "Tee" bolt, which goes into a hole in the front part of the frame muffler bracket.
Posts: 136 |
I hear it is easy to make the strap but as you know it... I need the bracket as well.
I hope someone has both.
Thanks Steven
Posts: 1,255 Likes: 10
Posts: 1,255 Likes: 10 |
If you are still looking for a muffler bracket I think I have one. It may take a little time to find it but I'm pretty sure I have one off of a hot rodded '30. Send me a PM.
