jayalb Offline OP
I am restoring a 1935 Master with knee action. Have tried, without benefit of the special Kent-Moore tool, to remove the caps on top of the knee action units, but have not been successful. Can you advise me:
1. whether the special Kent-Moore tool is available on loan or for purchase?
2. whether there are professionals who can restore these units?
Thanks,
Jay in Albuquerque
www.applehydralics.com They specialize in rebuilding them.
"Heaven is Driving my 47"
With that "GOOD GULF" gasoline.
http://www.gulfhistory.org/?
Jay,
The professional rebuilders are NOT inexpensive! If I remember correctly the process with tips on how to get them apart and back together has been discussed in some detail on ChatII. If you search (use advanced search and look at the tips) you should find more that should help you. Seem to remember there was an article in the G&D a bunch of years back.
You might ask PatS were he had his done
PatS Knee action photo
Jay, look at the tool I made in the photos at left. A piece of square tubing with a piece of 3/8 square rod welded to it. The rod is the width of the plug. If you catch both the plug and the cap it will turn the cap. If you catch just the plug, it will turn only the plug.
jayalb Offline OP
Thanks kindly, Pat. That's very helpful. Why didn't I think of it?
Jay
jayalb Offline OP
Thanks kindly. That's most helpful. I'm on my way now!
Jay
jayalb Offline OP
Thanks kindly. May give Apple a try if all else fails. Good to know about them.
Jay
Did you get the knee apart?
I assume you are doing this on a work bench and not with the weight of the car on the knee...
Mike B :)
Mike Boteler
1935 Master Technical Advisor
