On the mount (U shaped channel) for my '35 1.5 ton, there are 2 square holes for mounting the fender supports on each side of the mount. The mount bracket can only go one way because these holes are offset. Which way does it go? Top hole forward or to the rear? I didn't remove it so I have no idea and, I really don't want to find out the hard way.
Thanks.
Cornpatch Chevy Rides Again!
