Posts: 28 |
Hi I'm just finishing restoring my 1928 national sedan.I would like to know how the choke cable outer belden is clamped at the carburetor which is a carter RAKXO.Also from from the Aussie Chev nuts a drawing with dimensions of the hand trottle linkage from the steering clombe to foot linkage
dixies
A bracket is attached to the right lower intake manifold bolt that is about ~3 inches long that has a clamp on the end that secures the cable shield. If you still have a problem, send me a PM with your email and I will send a picture. If you have a RHD my picture will still probably help.
Posts: 79 |
The chohe cable is connected by bracket to the intake manifold bolt on my `28 I hope this picture helps with your throttle. ![[Linked Image from members.optusnet.com.au]](http://www.members.optusnet.com.au/milnej/chev/IMG_4280_1.JPG)
Your picture is on the way.
Posts: 809 |
I have a spare choke cable bracket if you need one. Chris
