#22780 12/11/05 03:49 PM
R.Smith Offline OP
Hey All,
I'm in the process of rebuilding the cab on my truck. I have most of the original wood to go by, but I think I may be missing whatever, if anything, went between the bottom of the cowling and frame. I just can't imagine that the heavy spamped pan on either side of the cowling sat directly on the frame. That, and the shifter is almost touching the dash.
And yes, I know it would've been easier to buy a kit. I thought about seriously, but the do it yourself idiot in me won out in the end.
Plus, now I have an excuse to buy wood working tools!
I can send pics of the area I'm talking about if it's not clear.
Cornpatch Chevy Rides Again!
#22781 12/11/05 09:34 PM
The cab on your truck had 1/4" thick flat belt type fabric pads. The front pad is 1.5" wide x 5.5" long and runs from the foreward cowl attachment bolt outboard over the "L" shaped bracket. The rear pad is 1.5" x 3".
#22782 12/11/05 09:37 PM
The hole in each pad is 1/2" diameter.
#22783 12/11/05 09:54 PM
I'm sorry I got the positions backward the long pad over the "L"frame bracket is in the rear position. The front pad is the short one. Both are fastened with a square headed bolt and square nut.
#22784 12/12/05 12:24 AM
R.Smith Offline OP
Jim,
Thanks. Flat belting I have! Miles of it. BTW, thanks for the check. It wasn't nessasary. That bumper was destined for the cupola.
This "wood" stuff is kind've fun, except for all the dust.
#22785 12/14/05 06:11 PM
Dear Mr. R. Smith,
Any excuse to buy woodworking tools is a good thing!
And yes, wood dust can become an issue. We have made a lot of these kits, if I can be of help in any way with advice or tips, call me sometime at 540-789-8300 M-F 8:00-4:00est. I may be able to help you get over some of the rough spots. Thanks,
Bill/ KC Wood MFG.
All the best, Bill
#22786 12/14/05 10:10 PM
Hi Bill, I have a question, I am looking for cross section view of the back window of a 34 chevy 1/2 ton. I don't have any thing that shows me how the window is held to the back panel? Thanks. stressed Babes like old Trucks.
easymoney
#22787 12/15/05 01:55 PM
The back window is held in a rubber "U' channel all the way around; butts up to the back metal panel & is held in that position by a 1/4 round molding again all the way around. The 1/4 round is 1/2" on each side and is nailed in place; miter the corners at 45 deg. All the inside visble wood and metal is painted a light apple green color with all the cardboard panel a medium to dark green. The bill or map pocket metal in LH side is painted black.
