Posts: 410 |
Looking for picture of rear mounts or good dwg for 51 std. Bell housing to frame. I have none. Thanks.
easymoney
I looked through all my stuff and can't find a picture. In short there was a bracket that bolted to the bell housing, a bracket attached to the frame, and a small mount that connected the two. Was used on 1949, 1950 and 1951 models.
Will keep looking
Posts: 1,178 |
The question came up in Chevy Talk, there is adrawing of the mounts there that is quite clear. Try Chevytalk.com and search.
Posts: 3,801 Likes: 1
Posts: 3,801 Likes: 1 |
Posts: 410 |
The pictures will help me in fabing brackets. Thanks.
easymoney
Posts: 1,113 Likes: 1
Posts: 1,113 Likes: 1 |
You might check with Old Car Parts in Portland, OR. They may have your mount bracket as they have lots of old parts . Easier than fabbing em if you can get em. If you're talking about the side mounts, Chevs of the forties has em too.
Rick
