Posts: 293 |
The column switch for my 28 National was cutting in and out and stalling out the motor, I took apart the switch and cleaned the whole switch inside and out and still had a connection problem???? Took a volt meter to the brass rivets that connect to the metal screw connections on the back of the switch, and had positive connection but when I put the volt meter to the metal screw connections I had no power connection?????? I cleaned the metal around the brass rivit butt and soldered the brass rivit butt to the metal screw connections and now have full power to the ignition system without any cut out. Hope this help's anyone that is having problems with there switch, somthing to look for on your rebuild.
Keeping vintage Chevy alive.
Someone posted an interest in reproducing this switch. Sent a PM and no reply. If you are still around, I have a sample switch you can use and also in the market for some of the switches. Send me a PM or email.
Posts: 277 |
sorry for the delay in response on the ignition switch. I would like to borrow one to see if I could figure out if they could be reproduced. I'll return it in tack after a few weeks.
Ron McCulley 6761 S Kit Carson Cir West Centennial, Co 80122
303 730 7073
Posts: 293 |
Hey Ray u may be thinking about the post that listed a tumbler mod for the column lock that was on a earlier post, that had a modified tumbler with key for sale..
keeping vintage Chevy alive.
Ho, I was looking for the fellow above. I plan to contact him and see what he can do for us. It is the ignition switch that is the critical part.
Hi Ron, Plan on giving you a call tomorrow.
Posts: 1,284 |
Yeh, ditto Jay28,
Did the same thing to mine, solder etc, worked a treat. No problems in 4 years, plenty before.
Cheers
Ray
Posts: 277 |
was out most of today, had to pick up a battery support for my 27
will ck my voice mail when I get home
meeting with a machinest friend on Sat see if we can come up with a method to stamp the sheet metal enclosure, have some idea's but "I'm an Elec Eng..if it don't spark I'll need expert mech help"
thanks ron
