#22589 10/12/05 10:54 AM
Can anyone tell me what was the last year that Chevrolet had the closed drive shaft? Thanks.....Richard
#22590 10/12/05 11:34 AM
In the car line, it was 1954.
Agrin
#22591 10/12/05 12:43 PM
Hi Ray, my next question is what years will interchange with my 36 pickup 4 sp.? my thought is if I can find a later differential and closed drive unit I can just swap them out to obtain a higher gear ratio. Thanks..... Richard
#22592 10/12/05 03:20 PM
If your 1936 pick-up is a 1/2 ton the 1935-36 Master passenger car drive shaft will interchange -only.
If you are a member of the VCCA note the ad in the Oct. issue of the G&D-parts for sale.Member is making a 3.36 ratio ring gear and pinion for that model.That will result in a great reduction in engine speed...and power....to an extent.
#22593 10/12/05 03:55 PM
He wants the later year 35 master differential carrier & propshaft housing asm. p/n 601277 marked with an "H" on frt. side of carrier (uses the Hyatt pinion rear bearing #C-1506 p/n 125630). It fits the 35-36 models EA, EB, ED, FA, FB, FD. The rear axle housing p/n 601925 is for the 36 FB only. Don't know how much or what is different than master car.
#22594 10/12/05 04:13 PM
If he has a 1936 1/2 ton the ring gear and pinion for the late 1935 and all 1936 will be the same as the all use the 601277 differential housing and torque tube.
That is the housing his truck will have.This is the ring gears Larry makes .
The 601295 is the banjo housing for the 1/2 ton and does not effect the use of the ring gear.
I was assuuming that he could use (or will use) his original assembly.....as there is no other (later) torque tube that would interchange.
Hope I didn't confuse oldred36 dance
#22595 10/13/05 10:04 AM
i just went through this changing my 35 to a 3; 80 ring and pinion .the question is where is the housing marked with a h i looked all over on both of the rear ends that i have and could not find any thing that looked like a H they are both late 35 rear ends with the hyatt pinion bearing thanks
#22596 10/13/05 10:55 AM
Chevgene, Is the guy that makes the ring and pinion Larry Jackson?, if so I've been told that he's making sets for 36s. thanks guys, appreciate the info. ...Richard
#22597 10/13/05 11:02 AM
Yes, its Larry....check his ad in the Oct G&D.
#22598 10/13/05 07:09 PM
The "H" stamped on the housing was as I found out was used in service parts not the original build; sorry.
