#225691 11/25/11 06:49 PM
Please, could somebody send me the planes of the gear box of a National, because I have restored it totally and te 2nd slides to the neutral in aceleration only. Or can somebody help me. I will be very gratefull. Please, I can't do no more than I have done...
Thank's to everybody.
Rafael63 #225901 11/28/11 02:22 AM
Hi Rafael63,
I would suggest that you check for wear on the end of the shifting lever , and the shifting plates, My thoughts are , that if you have rebuilt the gearbox earlier , and it is not staying in gear, that maybe they are not engaging the gears all the way.
There is a posting on here by 1928isgreat, that talks about how Ray repaired the shift lever and shiftng plates.
I would start there , and check these parts before you pull the gearbox out again.
JACK
Gooday Jack39,you have a good memory.
This is the posting
https://vccachat.org/ubbthreads.php/topics/173435/A_Gear_Change_From_Heaven#Post173435
And I did a posting with pictures in my blog if that helps
http://my28chev.blogspot.com/2011/06/2010-april-sloopy-gear-change.html
