Posts: 52 |
Can anybody tell me or send picture of the side motor mounts to Chevrolet std 1935? Are this true Chevrolet standard 4 door makes only 1935?? Thanks,Mikael
I have sent you two pictures.The mount with the part number 377928 - from the parts book picture is for 1935 thru 1948.The other picture shows the mount bolted into the car.Note that it sits on the crossmember and is attached to the bell housing bracket.The 1934 mount is attached to a bracket the is bloted directly to the side of the engine in 1934.
There is a late 1934 Standard 4 door that has the 1935 body only and uses the 1934 Standard engine that has the water pump attached to the head.The 1935 Standard engine has the water pump attached down lower to the block.
The 1935 Standard has an X member in the center of the frame - 1934 does not.
Posts: 52 |
THANK YOU Chevgene for the information it is OK.
Mikael
Posts: 22 |
Motor Mounts on a Standard Coach 1935. Dear Chevgene, It is me not clear where I how a can fit a 377938,near the clutch housing or near the radiator ? And I wish to know of type near the gearbox is ! Thanks for your help. Cor Hulkenberg, The Netherlands
Cor-note tht the 377928 rear mounts are smaller than the front mounts.........
Mikael-Your Email came thru blank-I have been having a problem..If it was a thank you your welcome.Gene
Posts: 2,299 Likes: 8
Posts: 2,299 Likes: 8 |
I have several of those 377928 motor mounts if you need some.
Posts: 15 |
Hello Gene, my rear engine mounts on 36 Chevrolet are real jelly and need replaced urgently. Can You sent me picture of it and corresp. number.
Are they simular to that of the 35 standard model? Otto
Oldiotto
Otto, They are the same mount.
