#224825 11/16/11 01:47 PM
jayalb Offline OP
I need a transmission cluster gear for my 1935 Master. It used the so-called "WM" transmission, made by Wagner, not the more common Chevrolet version. As I understand it,the cluster gear I need is unique to the 1935 Master models, and a 1936 will not fit. Any help out there?
Jay in Albuquerque
I recall hearing many years ago that this transmission was also used in a competitors car. You might look into FORD also. I'm sure someone will chime in with more details.
Member 45+ years, been around since the beginning !
Hi Jay, you might get a better response if you put this one thread down in the 33-36 site. Good luck with your project.
Sal Orlando
Chat Group Region Member
I have that cluster gear NOS. I sent you a E-mail.
