Posts: 110 |
I picked up a couple of trunk hinges the other day. They are not a matched pair and one needs repair. I think they are for an accessory trunk and need some help on the identification. One (the good one) says T-13891 on one half and T-13892 on the other half. The other says T-13887 on one half and can't get the old gasket off to read the other half. Could these be Ternstedt part numbers?? Any help appreciated! Thanks, Ron
Ron Holzschuh
Those are Ternstedt numbers which would lead me to believe that they are not from an accessory trunk.
The 1933-34 Town Sedan or the 1934 Sport Sedan (different) had some more unusual looking hinges.Can you describe them?
Posts: 110 |
Chevgene, I could eMail you a couple of pics if you send me your address.
T-13891 have mounting studs 5/8 center-center. T-13892 have stud spaced at 1 1/16 center-center. Length of this hinge is 4 3/8" long and 1 1/8" wide at the widest part.
T-13887 have studs 1 1/16" on both ends. Its 5 1/4" long and 1 1/8 wida at the widest part.
Ron Holzschuh
Posts: 977 Likes: 7
Posts: 977 Likes: 7 |
Ron, they are for 1933 and 1934 Town Sedan. T13891/T13892 is the center hinge. T13887/T13885 is the left hinge. T13884/T13886 is the right hinge.
Bill Masters
Posts: 110 |
Bill, Thank you for the information. I didn't realize these trunks used 3 hinges. We learn something every day!!
Ron Holzschuh
Waasn't the center hinge on the Town Sedan some kind of hold open device also.My Sport Sedan has no center hinge but I remember my fathers Town Sedan had some type of flat spring under the center hinge.The Sport Sedan had a folding link to hold the lid open.
Posts: 977 Likes: 7
The two-piece holdopen is mounted on the inside of the trunk, under the center hinge.
Bill Masters
Posts: 977 Likes: 7
I forgot to say the center hinge support is used on the 34. I think the 33 Town Sedan uses two supports, at left and right sides.
Bill Masters
The parts book lists the center hinge for the 1933 and 1934 Town Sedan.
The rear view/trunk picture of a 1933 T.S. in "A Pictorial History of Chevrolet -1929-39" shows a lid with no external hinges....must have been a proto type car.
Posts: 977 Likes: 7
Gene, That is an interesting picture of the 33T.S. without the hinges. The pictures do show the locks.
Bill Masters
