As I was checking the front brakes on my 36 pickup I discovered that the inner bearing races (next to the backing plate) are very sloppy on the spindle shaft,(1/8 in. sloppy) my question being; is it likely that the shaft is worn down that much or could it be the bearing race?, or both? Do I need to replace the spindles or would new races correct the problem? If the spindles have to be replaced, what about having a spacer machined to take up the slack between the shaft and the race? Thanks to anyone who can advise me on this problem.....Richard
