Posts: 131 |
I have a 1968 Camaro RS with some cool factory options a 327/300 L30 Console Clock and Smokeles Ashtray, it is also triple black and a Van Nuys built Black Plate beauty, any idea how many came with a console clock and smokeless ashtray? Thanks Denny
Posts: 3,163 |
PapaDenny The L30 for 1968 was rated at 275hp for the Camaro. There is no RPO number for smokeless ash tray. There is a RPO number for a lighted ash tray. The clock was offered as an RPO or a dealer add on. I can ask CRG if they have a total number on console clocks for a 68 if you wish...Joe
Posts: 131 |
Thanks Joe, appreciate your help, it look like a small vacuum line but it must be for transpodic illumination as light must travel through.The console has a special top plate to house the clock and is designed for the console and there is a factory wire harness that comes out of the main loom the the correct plastic connector
Posts: 3,163 |
I ask your question on CRG. I'll post when they answer Joe
Posts: 131 |
Posts: 3,163 |
PapaDenny Phillip from CRG just posted that 20,318 cars came with RPO U35, Console mounted clock....Joe
Posts: 131 |
Posts: 3,163 |
That figure is only for 1968 Camaro...Joe
Posts: 131 |
Checked it out last night, there is a small 1/8" plastic tube that attaches to the top ashtray holder and it is in the factory loom and terminates by the Vacuum side of the wiper motor with a tee.This was not dealer installed or it would not be in the original factory loom
Posts: 131 |
Have one more question, what is the correct center cap for a 68 RS Camaro? I have the tall center caps used on my rally wheels but feel they should be flat caps
Posts: 3,163 |
The flat ralley wheel cap was 1967 only...Joe
Posts: 1,194 |
Their are actually 3 different cap available for your rally wheels. The tall cap which where used on Corvettes and Monte Carlos. The early rally wheel caps ave a small raised center cap that is about 1/2" tall. I've seen them with the words "chevrolet" and also seen them with "disc brakes". The third style is referred to as a "police cap". It is a flat cap with a bow tie logo and stripes. I'm not positive how what years these were used, late 60's for sure. Don
