EDNY Offline OP
The door casing cover on the left has an aluminum dovetail wedge, the one on the right would use the plastic casing springs.
Anyone familiar with the one on the left?
Both were made by Ternsted MFG Co, Detroit, MI
[Linked Image from i15.photobucket.com]
Here's a picture of the backs:
33Master5W
34Master3W
The ones on my original 34 Master have the cast alloy ones, which are now pretty worn
Chris
EDNY Offline OP
Chris
Thanks Chris....you are the first to confirm seeing the setup.
33Master5W
34Master3W
The one on the left is the only one
I've seen in the 33/34/35 models
I was mistaken-I actually have some of those on the right with rubber bumpers from a 35 standard 4dr
