MN4896 Offline OP
Been looking every where to try to find a diagram on frame specs and measurements. My 28 coupe came as a big jigsaw puzzle and I need to find a starting point for mounting the body. Any help will be greatly appreciated.
Become a Member!
MN4896 Offline OP
Really??????????????? No one on here has anything like that?
I have a '28 Coupe but don't have the measurements handy. Neither is the car since it is temporarily stored 120 miles away. Do have a '28 frame here that is the same as are all '28 passenger frames.
MN4896 Offline OP
Yes, Mine is a 28. Just need some reference points for the cowl, etc...... Thanks Jeff
If you let us know exactly what you need maybe we can supply it.
That should be rather easy to figure out. There are a total of 8 body mounting bolts. 4 on each side (now how did I figure that out?). The first hole/bolt is about even with the front of the cowl, actually a couple of inches back. The other 3 holes are easy to locate now that you have the first one.
Agrin devil
