Hi Lexey, Thanks for the information. The Head is currently at an excellent machinists shop. We discussed the Head when I dropped it off. It will be taken apart, cleaned, Magnafluxed, and examined for cracks and how to refurbish will be determined. Do these Heads have removable Guides? I know we use Umbrella Seals on modern engines but are they advisable on these older type. The Water Pump Baffle is new to me. When I go out to the garage I'll check on it. The Rocker Arms look perfect thank goodness. I'm soaking the Pistons with MMO while the Block is open, thinking I may be freeing up tight, (from Carbon), Rings.
Thanks for your interest and stay well! Al
