#221284 10/10/11 08:27 PM
Mike33 Offline OP
I just picked up a vacuum operated fan which mounts to the steering column.Was this an accessory for a 33 Master Coupe?I am also looking for the bracket(clamp?)which goes around the column and connects to the fan.Any help would be appreciated.Thanks,Mike
Support The VCCA!
Mike33 #221286 10/10/11 08:42 PM
That is an accessory that was available in the '40's.
Chev Nut #221288 10/10/11 08:57 PM
Mike33 Offline OP
Thanks for the quick reply!
Mike33 #221333 10/11/11 10:27 AM
I have one on my 37. made by trico. It also did not have a clamp. I saw one at a car show and how the clamp was made,so I made one myself. easy.
chevy1937 #221509 10/13/11 01:55 AM
I don't know what year Chevrolet first offered fans for the steering column, but they had two types (metal & rubber) in the '38 Chevy accy catalog. They may have been electric fans? The clamp to this Trico vacuum fan should be easy to make:
[Linked Image from i27.photobucket.com]
Hayree38 #221646 10/14/11 04:06 PM
Mike33 Offline OP
Thanks for all the replys guys.The last picture will definitely help me make a new bracket.My fan has a single flat slotted bracket on one side.Any idea what that was bolted to?
Mike33 #224215 11/09/11 07:48 PM
I recently picked one up for my 37 p/u,not sure on who made it but I do hope it helps to defog the windshield. Probably will need to get a dual diaphram fuel pump for it to work the best.
VCCA #45194
junkyardjeff #224258 11/10/11 02:26 AM
Item number: 300619464986 Thought you might like to see this on Ebay , one day left , bids at $41.00 , different mount, Trico....vacuum fan...
