Does anyone have or know where I can find dimensioned drawings of the construction of the rear seat armrests for a '36 Master? I ordered the Hampton kit and they said they do not have patterns for the support structure underneath. Any help is appreciated!
Can you not take dimensions from the supplied upholstery and construct some base structure? I would use Styrofoam to carve the pattern and transfer to wood after I got something I was happy with. This would work if you cant find a drawing.
J Franklin
Do you know if they're much different from a '34 back seat armrest? I have a set of those from my '34 Master parts car.
I don't actually know if they are. I think I may have found some forms in a pile of stuff that came with the car, so I will see if they line up. I am just not sure how it all goes together under the fabric. Thanks for the time to respond to all.
