#220985 10/07/11 12:31 PM
Hi all. I'm getting ready to button up the oil pan on my '31 coach and was wanting to know how to properly use gasket shellac? I'm trying to stay true to the "old school" techniques, but haven't had any experience with shellac. Should I let it dry completely or just tack up before I apply the gasket? Should I use it on both sides of the gasket? Any info would be greatly appreciated.
Thanks again,
C.J.
"If a guy doesn't use his head, he might as well have 2 a**holes!"
Judging from the reviews and lack of posts I would think that few if any are using gasket shellac. I like to install gaskets dry and no sealer except maybe at joints or in this case a few dabs of adhesive sealer to hold the gasket to the pan. That way if and when you have to remove it again you will hopefully avoid a lot of scraping.
m006840 #221101 10/08/11 09:17 PM
Only thing I ever use is Permatex #2. I only put a dab on the four corners of the oil pan. The best way to hold a gasket in place is to tie it through several of the bolt holes with a fine thread. The thread can be cut off after assembly.
i remember using shellac. i think we put it on one side of the gasket and the corresponding side of the block or pan, then when tacky put them together. a lot like permatex i think. i remember greasing the other side of the gasket after installation, then when you need to separate them you don't have the need for a new gasket always.
they don't make em like they usedta
And I thought you fella's would be in to my favorite : "Gask-a-Cinch", I see it's still out there...label has a gal with a gasket about to land on her rear as a race car speeds by...
a friend of mine who does Hemmings antique restorations turned me onto EZturn from Spruce Aircraft and I love it-also is best neverseize I've found-doesn't leak and can parts can easily be separated
