#220194 09/28/11 11:05 AM
Beamer Offline OP
hood Can anyone tell me the thickness of an oil filler cap gasket? Mine disintegrated and I can't find the piece I kept for that dimension. I know they are cheap to buy but I hate to pay 8 or 10 bucks shipping for a $1.50 item. Since I have lots of cork stock of all sizes, I thought I would make one but I need to know the thickness for a proper seal. Chevy's of the 40's has the inner and outer dimensions but not the thickness. Thanks. Beamer
Chat Region Member
2017 GMC Canyon
I'll go out and check mine in a bit. I agree that making your own is a lot smarter than buying one if you already have the cork.
Mine was about 1/8' thick on my 38 Master but it was starting to fall apart so rather than have pieces fall down into the oil tube I scrapped it out and replaced it with a piece of rubber roofing I cut out to match and glued into the cap...It fit real good and you can feel it seat and get tight when you turn it on Good Luck....ED
I'd have to agree with the 1/8" estimate. I pulled mine but I couldn't remove the old gasket for an accurate measurement without destroying it.
I also agree with 1/8. I have the cork also and it tightens nicely.
In the later years the gasket that came with the Genuine Chevrolet complete engine gasket set was made from neoprene rubber and lasted much longer than the cork
Beamer Offline OP
bana2 Sorry for the delay in my thanks to everyone but I am still battling an excruciating sciatica problem in my right leg and therefore not on the computer a lot. In any case, many thanks to all the responses. They told me what I needed to know. One of these days I will come across a small piece of cork (part of the old gasket) wrapped in a piece of paper and wonder where it came from but by then, I won't need it. Beamer
Chat Region Member
2017 GMC Canyon
I also had a major sciatica problem last year. Finally got in to see a Neurosurgeon and it was a good thing that I did. He did microscopic surgery and when I recovered from the operation, later that day I walked out of the surgery center and headed home pain free and my back has been 100% ever since. Actually, my back hasn't felt this good in about 10 or 12 years thanks to the surgery.
Same here had a discectomy (spelling)been great ever since
