#219440 09/18/11 05:51 PM
Tiny Offline OP
What years are exactly the same as '38? I believe '37, '38 and '39 are but I don't know that for a fact. Also what years are the key end of the electrolock the same? I'm putting together a restoration document on rebuilding one and I'd like to know how many model years the information is accurate for. I spent the afternoon rebuilding the one out of my '38 and took a LOT of pictures of the process.
Book say:
ELECTROLOC ASSEMBLY:
37-39 All Pass Less cyl and keys ("D-37" cast on case). Pt# 1865216
35-46, 47 All Pass, 49-53 All Comm. and Utility CYLINDER less keys uncoded
Pt# 1097319
Hope this helps,
Tiny Offline OP
You need to understand my feeble old mind Charlie. If it says 37-39 all passenger is part number 1865216 but it also says 35-47 all passenger is part number 1097319 it leaves me a bit confused. 37-39 fall into the 35-47 range but with different part numbers. crazy
Tiny,
It just means that the "Cylinder" is the same. Nothing more.
Tiny Offline OP
Thanks Charlie.
Tiny Offline OP
One last question guys, what is the gauge of wire used on an electrolock? Just by looking I'd guess 16, close??
14
Ken Ippolito
1936 Master Deluxe Town Sedan ,1938 Master Town Sedan, 1950 Styleline Deluxe
CHEVROLET, The only complete low-priced car
Tiny Offline OP
14 it is, thank you. ok
You Bet
Ken Ippolito
Be sure to use high temperature insulated wire or cloth coated. Standard insulation will melt inside the cable and short out the wire.
Richard
Waverly, IA
Tiny Offline OP
Thanks guys.
