I'm installing new C & T Cables and just not sure which holes are correct. Can anyone out there Please describe the proper routing ? Would like to cut them to the right length and before I get ahead of myself...I have a vacancy ,left hole of the 3 hole grommet (throttle cable ?)...Looks like the Choke wants to come through the (center) single hole grommet or is that for the key switch/coil cable ?
On my '40 the throttle, choke and oil tube go through the one in front of the driver. The Electrolock cable goes through the one lower and in the middle.
