buckeye Offline OP
I'm installing a new radiator in my 4dr confederate.
My question is the 2 bolts on the bottom of the radiator shell were rusted off, do the new ones get welded in or do you use a carriage bolt. I noticed that the bottom hole is slotted like it was designed to use a carriage bolt.
any information will help.
Thank You
Buckeye
You can either use a carriage bolt if the head is flat enough or an elevator bolt (they have very flat heads).
buckeye Offline OP
Thank You for the reply, I have both bolts, will see which works best
buckeye
