Fleetline,
I suggest the following:
a. Go to the 37-42 forum and look at "Call me stupid..." It's about tune-ups. All the advice and information will apply to your vehicle, as well.
b. Take the vehicle outside.
c. Get a new set of points and plugs.
d. Squirt some WD-40 in the cylinders whilst the plugs are out.
e. Turn the engine over several times and then Install plugs and points.
f. Ease the carburetor apart and clean it up. Be careful. Be prepared to buy a kit. (For short term you may pour a small amount of raw gas in the carb. Be real careful and have a fire extinguisher handy. Again, make sure it is outside and away from anything that may catch fire. Do all this with a trustworthy and bright buddy.)
g. Gap the points until a time will fit in the gap when they are fully open.
h. Turn everything off but the ignition and use a 12 volt battery and crank it up. If it doesn't fire then its not getting gas, ignition or is out of time. Have your buddy hold a spark plug wire to check the ignition part. Beings he is smart you may have to call on another buddy. You know.
i. If its been sitting for 20 years, chances are that you will need a new gas tank. Installation is a piece of cake.
j. After you get it running, sell it. Get yourself a 41 Special Deluxe coupe. Grin.
Good luck,
Charlie
You will also need to check the block for rust stop-up and radiator for the same. A lot of stuff can go south whilst they are sitting around for a right good spell.
