Posts: 3,192 Likes: 8
Posts: 3,192 Likes: 8 |
Hi all, is there a member who reproduces the 1931 and 1932 horn diaphrams? my 1932 horn motors have rust holes through them! Thanks
JACK
Posts: 3,008 Likes: 1
Posts: 3,008 Likes: 1 |
Probably one out of a Harley Davidson horn will work.
Joined VCCA June 1, 1961
Thanks for the suggestion, are they delco remy horn motors as well?
JACK
I don't know who makes the Harley horn. I know that some folks have mounted them on 31s because they could't find an original 31 horn. They are close.
Delco horns were used on Harleys, Plymouths and a few other cars. Also sold aftermarket for any vehicle.
Posts: 88 |
I assume you still have a 6 volt system, I found a 6 volt motorcycle horn on the internet that I was able to insert into the outer case of my old horn. It worked.
Jim G
Posts: 77 |
Hi Jack, did you have any luck sourcing the diaphragm plates?
