#21881 02/28/05 07:47 PM
Hello - There are currently 2 '36 1/2Ts for sale on e-Bay (4529331897 & 4529382210); both about to end shortly. Question - which headlights are correct? One has longer bullets with a small marker light on top and one has short bullets (more along the lines of '33). I'm trying to identify a set I have, with the marker lights and I came across the the '36 with the headlights I have. Then I saw the other truck with different headlights. I'm confused.
So which one is correct, or what year are my headlights with the small marker lights on top?
Thanks for whatever info you can provide!
#21882 02/28/05 10:43 PM
Headlamp for 36 trucks are the same as 34-35 black body, chrome rim similar to 33 car but without the triangle bead at the top of rim. Park lamp is inside headlamp not on top.
#21883 02/28/05 10:57 PM
The green truck with the larger lights are correct.The blue truck has later after market sealed beam replacements made for "any" car
#21884 03/02/05 12:12 AM
Thanks for your help with this one!
