#218744 09/09/11 11:15 PM
Just got my seals to install the front suspension and ripped one! The upper outer seals are supposed to stretch over the arms before you send the pin through but these seals have little stretch at all and forcing it just split one. Does anyone have a different method for these? It seems like this is the only way but the replacement seals just aren't up to it!
I'm not sure Steele makes this item or not but I would believe they would have the proper elasticity if they did. dance
Where did you get yours? hood
I got them from Chevs of the 40s
Had the same problem about 8 years ago. Found comparable 'O' rings/seals at Lowes in hardware section. Was concerned about durability when exposed to lube grease but at last greasing (this spring) the Lowes seals still looked good.
