Posts: 293 |
Putting my motor back together and was looking up torque spec's for the: main bearing caps, head bolt's, and con rod's and could not find any info on these spec's. Does anybody know the torque specs for these parts? any help would be great.
Keeping vintage Chevy alive.
Posts: 408 |
Well these things were before the concept of "Torque Specs". They used words like "tight".I do however remember asking an engineer about torqueing down a cylinder head and mentioned 75 lbs which was what was listed for a 1950 Holden. His reply was that 50 lbs was enough.I am sure other people will come up with figures that have evolved but basically "tight" but don't keep going.
Posts: 809 |
Torque specs relate to bolt type and size, nothing to do with the brand or car. The main thing to consider is "are the bolts stretched" head bolts usually are. My suggestion is to replace the bolts with studs and tighten down with nuts, lessens the problem of stretching. Remember how old these bolts are and the quality of original ones way back then. Basics I use are Head max. 50lbs Conrod bolts 30 add Mains as tight as you can get them, around 80-100, helps reduce failure of bearings Any bolt supply firm should be able to give you specs as would possibly a Google search Chris
Posts: 293 |
Thank's for all your help guy's, now I can finish up my motor and awaken this old motor from a 40+ year slumber. Can't wait to hear the motor fire up.
Posts: 293 |
I forgot to ask what should the connecting rod clamp bolt to piston pin be for torque 30lb's ? Doing a final check on everything and hope to have it running this weekend.
30 to 35 is sufficient for the piston pins.
Posts: 1,284 |
Hi Jay28,
Good luck with the first start up, there is nothing like it.
Last weekend I helped a mate on the first start of his thumping big 38 Lasalle V8. Fired within 2 seconds, timing out to buggary,turned the dizzy, set the timing with the earchrometer, purred like a kitten. Almost as good as, well you know what.
Let us know how you get on.
Cheers
Ray
Posts: 293 |
Thank's Guy's for all your help with the torque spec's. I checked all my bolts for torque and had a couple out so re torque them. I primed the oil pump and primed the fuel pump and a little shot of gas down the spark plug holes for a guick fire to get things going, then tried to start the motor, it took a few crank's and then she fired up and burped a couple of times then started, followed with the bad smell of 40 + years of not running,but soon went away, had to tweek the carb a bit and now is running better. I'm going to run it until it heats up good and then I'm going to recheck the torque on all bolt's to make sure they are with in spec, it is sure nice to see that all my hard work trying to get this motor built and finaly get to see it running, what a thrill and I would like to thank all VCCA members that helped make this happen. You guy's are great and thank you very much.
