I'm fairly certain the rear springs on my 1934 Master need to re-arched. The car looks low to me. If anybody is in the back seat its really low.
What is the correct height for the rear of the car and how do you measure it?
I can find specifications in the manual for the knee action system but I can't find specifications for the rear of the car.
Thanks,
Jeff
1934 4 Door Master
1927 Runabout truck
1937 1/2 ton truck
1957 Nomad
If you can't find the height in a reference, you can always specify the added height you wish the car to sit to the shop that will do the work. This has worked for me in the past.
J Franklin
Chevrolet did not furnish any specs for the rear.
When viewed from the side The top of the tire should be about 1 or 2" below the top of the fender opening.
