#21714 02/04/05 09:06 AM
Landman Offline OP
Hi guys,
What do you suggest I use as insulating tape between all the brackets and the wood parts on my '34?
Just regular canvas?
Best regards, Landman
#21715 02/04/05 09:37 AM
I used black friction tape......joe
1931 Sedan Delivery 31570
1968 Z/28 Camaro
1969 SS 396 Camaro
#21716 02/04/05 10:33 AM
Friction tape is also suggested in the Fisher Body manual.
#21717 02/04/05 11:51 AM
on the vehicles that i have taken apart and restored these pieces appeared to be made of some type of asphalt paper so i use tar paper seems to work . hope this helps oldpush
#21718 02/04/05 01:23 PM
Landman Offline OP
Thanks muchly,
I'll use the friction tape.
Best Regards, Pat laugh
#21719 02/04/05 01:29 PM
On my 1930 coupe, leatherette was used in the key areas between the brackets and the body wood. laugh laugh laugh
#21720 02/04/05 01:47 PM
In the last few days JimG emailed me as to what was used.He found pieces of mohair upholstery material in his 1935.
Looks as if they picked up any scraps that were laying on the floor
#21721 02/05/05 03:32 PM
More on the upholstery material in the joints. The pieces I removed as I was disassempoling my 35 Master were all neatly cut rectangles with holes for bolts to pass through. These pieces were between each metal to wood joint that was still intact in my car. Each piece stuck out bit beyond the joint itself (maybe 1/8 inch all around). In the joint, the material was saturated with an asphaltic goop - still somewhat soft. I was considering trying to get some scraps from Hampton Coach to put in my joints as I install the new wood. Is going too far to be authentic? :confused: stressed
JimG
#21722 02/05/05 07:16 PM
Yes, but if you need some scraps I have them.
#21723 02/07/05 04:22 AM
xxx Offline
Is this the type of tape you are looking for??
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=3872719038&ssPageName=STRK:MEWA:IT
Good luck with the restoration.
croc
#21724 02/07/05 12:37 PM
Friction tape is what Gator pulled up on eBay, the Fisher body manual shows it being used several places. It is available from McMaster and is on page 3195 in their online catalog..
Friction Tape
This traditional black cotton electrician's tape provides an abrasion-resistant shield for overwrapping low-voltage splices. The rubber adhesive applied to both sides of this tape works as a nonslip surface when applied to tool handles. Total thickness is .015". Dielectric strength (the ability to withstand electrical voltage without rupture) is 1200 volts and tensile strength is 40 lbs./in. width. Temperature range is 0° to 194° F (apply at temperatures from 40° to 100° F). Tape is supplied on a cardboard spool with a 1 1/4" ID. Meets ASTM D69 requirements.
Per Roll
Lg., Roll Case Partial Full
Width yds. Dia. Qty. Case Case
3/4" 20 3 1/2" 20 76465A1 $2.51 $2.27
1 1/2" 20 3 1/2" 20 76465A5 5.61 5.08
...It is the old timey electrical black rubber impregnated cloth tape us oldtimers used before 3M came up with the plastic electrical tape that has been in common use since ???????
(this photo is from eBay)...
[Linked Image from i16.ebayimg.com]
A side note. Plastic electrical tape is NOT original on cars built before 1948 and maybe up to 1954
#21725 02/07/05 01:49 PM
a couple weeks back, we pulled up the '40 kc toeboard for the first time and found some remnants of cloth strips along the left & right sides...looked to us like it was to prevent squeaks?..would this have been canvas or dessicated friction tape?..
ok epi
#21726 02/07/05 02:08 PM
Did it look anything like seat upholstery material as in my 35 EA?
JimG
#21727 02/07/05 03:46 PM
xxx Offline
Thanks for the site, some cool stuff:
Page 3194 in the catalog has 'glass' cloth elec. tape.
"Scotch 27 (Class B) and 69 (Class H) Glass Cloth Electrical Tape… This tape is corrosion and puncture resistant. It has a woven glass base and won't shrink, rot, or burn. Adhesive is thermosetting, becoming stronger at high temperatures. Tape has no liner.
#21728 02/07/05 11:40 PM
Gator, I was clued in to this site by the guy in Floriday that writes the stuff about his work on the Advance pickup. I will have to look up his name...I have a bad case of C.R.S. today!
Ok he is, LAROKE and his truck is Billy Bob..
#21729 02/08/05 03:26 AM
xxx Offline
Thanks to both of you then MrMack.... laugh
croc
