#216782 08/19/11 07:12 PM
Mike33 Offline OP
I just purchased an NOS speedometer for my 33.Should I lubricate it before installing it?If so,where do I lube it and with what kind of lube?Thanks in advance.
Mike33 #216798 08/19/11 09:24 PM
Only a light oil, like clock oil or similar should be used. Some use WD-40 (fish oil). And no matter what oil you choose apply sparingly.
Actually WD-40 is a very poor speedo lube.
A light machine oil is better.
Unless you know how to completely disassemble and reassemble the speedo, I wouldn't do it.
Any man that thinks he is too old to learn something new probably always was
Coley #216850 08/20/11 10:55 AM
Mike33 Offline OP
Thanks Guys
Mike33 #217100 08/23/11 05:23 AM
Thanks for the info.
I have a clock repair business. It's not uncommon that I receive clocks that the owner tried to fix. I would highly recommend you send it to somebody who knows what they are doing. And no, I don't repair speedometers. Speedometers are probably similar to clocks in that some parts need oil, some parts need grease and some parts should not have ANY oil or grease.
Contrary to the rumors, I'm making great progress on the bulb. So far I have found 169 things that won't work.---Thomas Edison.
