Note that the early models (1950 -1952) started out in high gear. 1953 was the first year they started in low and then shifted "automatically".
Thank you for that information. One article I read (because of what you wrote) gives me the impression these transmissions through 53 were problematic.
Sluggish off the line causing the drivers to have a tendency to leave the transmission in low gear too long( little confused which year there) From what I'm reading doing this would damage the internals.
At this point I'm just learning but spend a lot of the time confused and only coming up with more questions.
Which is the great part of learning.
My goal would be to purchase a car that is an automatic and keep it original with the 6 but I have a feeling I'm going to have to swap out the motor and tranny.
