Posts: 10 |
Hello Everyone,
I am working on a 1951 StyleLine Deluxe. 216 and three on the tree.
I could really use some help trying to get the oil pan out to replace the gasket. The engine and transmission are still hooked up. Do i have to remove the crossmember? or anything else?
Any help would be greatly appreciated.
Thomas
Posts: 3,801 Likes: 1
Posts: 3,801 Likes: 1 |
Thomas, Look at and follow steps 1 and 2 under the oil pump removal instructions. Click here ... http://chevy.oldcarmanualproject.com/shop/1949_53/06engine/6_020.HTM
Unbolt the center steering arm ( idler arm) and drop it down. Not necessary to touch the motor mounts.
Posts: 10 |
Thank you!!!! i just got it off. There is about 50 years of gease built up on everything....huge mess
Thomas
