My Dad is 35Mike and he has been working on a 36 truck for a while now. Today it went on it's maiden voyage And I thought you guys would like to see all of the progress that he has made on a really cool project.
In 2005 my Dad and a friend of his found a cool truck and trailer in a field in Mo. The Truck was pretty far gone but the fifth wheel and trailer were very savable.
My Dad stared looking for a 36 truck to go with the trailer and found a great truck in south western Kansas. It was a 36 low roof 1 1/2 ton truck the only problem was that it had the wrong wheelbase. The truck was so nice, rust free, straight and original that he figured the wheel base could be changed.
As soon as he got the truck home he got it running but it did not seem to have much compression. This did not stop him from taking a ride around the field at my grandparents farm with no brakes. After this short ride the truck was stored for a while and was only worked on from time to time. But all the while my dad was gathering parts and making plans for the truck.
His plan was to remove the hoist and then shorten the frame 26 inches to make it into the short wheelbase model like the original. The head had been removed to find a number of burnt valves and was fixed with NOS pieces. King pins were replaced and the brakes were completely gone through.
A few months ago he moved the truck to Show Me Powder Coating his business so he could work on it inside where there was a lot more room and he could do things after work without having to go too far to get to it. Things started to move pretty fast at this point and there were a number of things on the truck that were not able to be finished until the truck was shortened.
So plans were made and with the help of my Dad's good friend Joel they got the truck to it's current shortened state in one Saturday morning and a few hours in the afternoon. The only piece they needed to do this was a shorter intermediate drive shaft and it happened to be one of the only pieces that was still salvageable from the original truck.
With the truck short the brakes could be finished and the motor was almost back together. In the last few weeks he has gotten a ton of things done. The back rest was recovered as it was the worst of all of the cushions. Before he got the motor all back together it was washed to get all of the years of grime off, the whole rear end was washed as well. A new windshield was installed as was the manifold and carb and exhaust. The motor started easily which was nice because he ended up putting new standard rings and checking rod clearances while it was apart. The pan and all of the engine tin was powder coated while it was off.
I live in WI and came down for a week visit yesterday and today my girls and I went to my Dad's shop to see the '36 and have my girls go for a ride.
I grew up around old cars, I rode home from the hospital in my folks '35 Standard Coupe. My first vehicle was a '38 one ton truck that was my sole transportation for a few years (I still have my 38). A few years ago I was in a bicycle accident that left me paralyzed, one of the things that I had come to terms with after my accident was the fact that I would not be taking many rides in prewar vehicles and this big truck was no exception.
My Dad had other plans. With the passenger side door removed and the use of a fork lift with a piece of plywood on the forks I was raised to the perfect height to hop right in. I was proud to be the first to take a real ride in the truck on it's maiden voyage. It rides a little rougher than my 38 (which I was not sure was possible) but what a great ride it was. We made a trip around the shop in the grass and then we took to the road to see if all of the gears really worked. Just as we were about to pull out onto the road I said "We are about to find out how round these tires are." The answer is not that round. It seemed to have plenty of power and zipped right through the gears as we ran down the road and the brakes seemed to work well. After we got back my girls all had a ride or two and I think it was quite a success!
There is more to come, the hood will be back on soon as well as the passenger side door, there is a new wiring harness that was waiting for the truck to be shortened, all of the vacuum brake parts that were on the original truck will be transferred to the this truck as they are redone. The next big step will be to mount the fifth wheel, it will need some oak cribbing under it but other than that it should not be much trouble.
The trailer is now rolling and the lift gear is freed up, there is still no deck on the trailer but the only thing keeping the two apart once the fifth wheel is on is distance. It should be quite a sight to see this rig running down the road again.
This is the original rig as it was found
![[Linked Image from lh6.googleusercontent.com]](https://lh6.googleusercontent.com/-6E6K1SG3Xxc/TjdDDx3j0AI/AAAAAAAACEw/ad0pnQt7mM4/s800/P1010004.JPG)
![[Linked Image from lh5.googleusercontent.com]](https://lh5.googleusercontent.com/-bTWiIaklMZE/TjdDJKnF7cI/AAAAAAAACFA/9HDNVJqojdM/s720/P1010008.JPG)
![[Linked Image from lh6.googleusercontent.com]](https://lh6.googleusercontent.com/-3Ibjv5IeeR4/TjdDKe5B5KI/AAAAAAAACFE/dghQ9vgt5Ok/s720/P1010009.JPG)
This is the rig on moving day with every thing cleared away and off of it.
![[Linked Image from lh5.googleusercontent.com]](https://lh5.googleusercontent.com/-d6qb4o1i9gU/TjdDlPr5ChI/AAAAAAAACGk/upe07uFf5s0/s720/P1010018.JPG)
![[Linked Image from lh4.googleusercontent.com]](https://lh4.googleusercontent.com/-p-5GxaJ2qus/TjdDmb9_dyI/AAAAAAAACGo/67weckYUIwI/s720/P1010019.JPG)
![[Linked Image from lh4.googleusercontent.com]](https://lh4.googleusercontent.com/-WA9HQ2FmA-o/TjdDwSYbMVI/AAAAAAAACHI/nZACIcYrBHs/s720/P1010027.JPG)
![[Linked Image from lh6.googleusercontent.com]](https://lh6.googleusercontent.com/-4mA7fSM0jZQ/TjdDzxDnS5I/AAAAAAAACHU/RJshCliF7sM/s720/P1010030.JPG)
This is the new Truck (tractor)
![[Linked Image from lh5.googleusercontent.com]](https://lh5.googleusercontent.com/-mIea-0FjJx8/TiZDtCtWfKI/AAAAAAAABrs/HkRduYcywXM/P4300156.JPG)
![[Linked Image from lh3.googleusercontent.com]](https://lh3.googleusercontent.com/-tOkHTDxbFig/TiZDtwGNpdI/AAAAAAAABrw/aNcqs6OAcbk/P4300157.JPG)
![[Linked Image from lh6.googleusercontent.com]](https://lh6.googleusercontent.com/-abdRRTaeZ9s/TiY_8ZSOQ_I/AAAAAAAABqs/PzCFeJXPoZM/s720/P7130006.JPG)
