Hi jgeorge, I need some help with your pictures. The first picture I can see where the pressure is applied, but how is the device connected to the hub? The second picture I need help also. The big puller has it's uses, but I don't think this is one of them. If you haven't given the loose nut tactic a true try, do so, it works.
Posts: 3,192 Likes: 8
Posts: 3,192 Likes: 8 |
Ray , There is 6 holes drilled in the upper round plate which would pass onto the wheel studs in the hub , and then be secured with wheel nuts.
The second question is in regards to the anchor pin for the brake return spring. It is pulled at an angle from the tension of the brake return spring. It look to me as if the pin has deformed in the backing plate where it attaches.
JACK
Posts: 558 |
Hi Joe,
Wow, what a puller!! I used one like the latter and it worked great on my 32 rear brake drums. As for the pin, it just locates the brake shoes ton the backing plate and is a bit loose. When removing the brake shoes, it will come out of the backing plate if you work it around a bit. When dis-assembling your shoes, just carefully pry part the Ring on the back of the shoe to remove the pin before you send the shoes off for rebuilding; careful not to break it if possible. The round pins that are used with the links to attach them to the shoes are hard to come by as are the clips that hold them on. I just finished my brake overhaul so if I can help in any way, let me know.
Mac
OK, now I understand the puller with 6 holes. Still at a loss on the second picture. This area is rot revealed until the hub is removed.
Ray, Joe was asking if the upper pin in the photo with the spring attached is supposed to be at the angle it is , or if it is supposed to be perpendicular to the backing plate, and if there is a fix for it.
JACK
Posts: 127 |
Those pins on my '30 all seem to be at an angle, worn some. It must not be too critical that they be at a right angle, considering how Chevrolet just put them through a simple hole. It bothered me at first, too. I thought they should have had threads, and a nut, to tighten them straight. But my springs never seem to come loose (slip over the groove), even at the angle, and my brakes work really fine.
Doug
SEE THE USA.......
Old Iron (cars, trucks, tractors, fire truck) Too much, never enough........
Those pins need to move with the brake shoes. The angle depends on the amount of lining on the shoe and adjustment of the brake activating cam. If they can't move then the brake shoes will not either. If you take out the pin and examine it closely you will find the outer part is actually rounded so it can rotate.
Posts: 48 |
Thanks for all the information on the brake shoe pin. I guess I will leave well enough alone for now. Regards,
Joe
I got it, I got it, now I know what pin is the object of the discussion.
Posts: 11,162 |
I figure that pin should have been pressed into the backing plate, I would be tempted to spot weld it on the back side of the backing plate in an upright position. I have that problem from time to time with the pressed in pins on the idle pully support of a couple of riding mowers I "fixed-up" and sold usually for less than I bought them for. My cash flow is going the wrong way, one of Oboma's financial advisors told me I need to buy a lot more mowers!
People with only modern brake experience have a hard time understanding why a solid pin should move. Its purpose is essentially the same as the spring, stud and cup used to hold modern brake shoes in position.
Posts: 229 |
Your's is a variation of a cage puller. I built one years ago and I found that it was the only puller that did the job where other pullers failed.
