Posts: 648 |
I was just curious...those battery maintainers out there that they sell to attach to the battery terminals with the battery still installed in the vehicle, which in turn is suppose to maintain your battery so it that it "never goes dead". Do those actually WORK...or are they just a gimmic to drain your battery faster and leave you stranded?
These are not the external chargers that we know of that plugs into a cord. They are mobile with the car...and it's not a jumper.
In my shop, quality is a standard, NOT and option.
Posts: 714 |
I have a solar battery charger that plugs into the cigerette lighter. It says that its output is 12vac 1/2 amp. Whether it works in maintaining, I can see no difference. Bought on "As Seen On TV".
Ken's 1940 Special Deluxe Sedan 1970 Cadillac Hearse
Posts: 238 |
I have used them and they work well. One word of caution, make sure you have water in your battery at all times.
Haggerty Insurance reports a number of batteries that have blown up because they ran dry. Since many early batteries were under seats or under floor boards they can do real damage if they blow.
David
Sunbird advice: When the temperature outside is lower than your age, it is time to head south.
Hubris is as hubris does!
Posts: 648 |
I was thinking along the lines of something for my newer car. The old chevy gets a trickle charger but you kaint hand crank the new cars!
Posts: 1,866 |
Just punched in Battery Butler [img] http://www.lectriclimited.com/battery-butler.htm[/img] and I see they have a Battery Quick-Disconnect for $10. Anyone ever use this one. Thanks.
Posts: 1,866 |
Thanks for the heads up on this thread Dawg. I'm gonna order the Battery Butler and Disconnect at the same time.
Posts: 1,866 |
