#215677 08/07/11 05:37 PM
hi guys, I have a question or should I say I need help. my amp meter aways shows just below the center line on the discharge side, when I turn lights on it goes down to the 1st line on discharge. then it will bounce back and forth when I put on the turn signals. I've never seen the gauge on the charging side of the amp meter, my battery has not gone dead but sometimes it cranks slowly. I cleaned all the connections on the voltage regulator cleaned the battery terminals. could the wires be crossed on the back of the amp meter? and thats why it dosent go to the charging side of the amp meter?
thank you
Jack
1941 Master Deluxe 2 door Sedan
original unrestored driver
http://i762.photobucket.com/albums/xx270/junkman41/car.jpg
junkman41 #215679 08/07/11 05:51 PM
Check the generator and cut-out or regulator. Your description is typical for generator not working.
junkman41 #215715 08/08/11 05:38 AM
Junkman....Great looking car.....Nice looking dog and wonderful 6 hole birdhouse. Good luck...ED
junkman41 #215718 08/08/11 07:33 AM
I found this chart for my farmall cub on how to test the 6v gen/reg would this be the same on my 41 chevy
Thanks Jack
[Linked Image from i762.photobucket.com]
junkman41 #215745 08/08/11 01:29 PM
This is a great, simple flow chart. My question would be does your tractor and '41 Chevy both have the same ground, negative or positive? If they do, I don't know why this would not work for either. If one has a positive ground and the other has a negative ground, then I wouldn't know. I hope someone who does know answers your question. This would be a very good diagram to have if it works on a 6v car. Beamer
Chat Region Member
2017 GMC Canyon
Beamer #215747 08/08/11 01:51 PM
Old Farmall Cubs have positive ground.
junkman41 #215788 08/08/11 05:38 PM
yes the tractor has positive ground, so that chart will not work then, is there a way that I can check the regulator to see if it is bad before I go buy a new one. I dont have a amp meter, I do have a volt meter
thanks guys for your replies
Jack
junkman41 #216080 08/11/11 07:35 AM
Junkman
With my limited auto electric knowledge I think that flow chart would work on all 3 post regulator (6 and 12 volt) systems. Someone like JYD who has more experience than me may like to correct me.
tonyw #216090 08/11/11 10:20 AM
Tony,
I agree. The chart will work with either positive or negative ground systems. Yes the electrons flow in one direction but it does not matter when testing an electrical system unless a diode or other one way device is installed incorrectly. As long as there is a complete loop those little electron fellas (or gals or both) will figure how to get around.
Chipper #217904 08/31/11 06:53 AM
I had the gen. and reg.tested and both were bad, so I had the generator rebuilt and I replaced the voltage regulator now it charges great. I hope that the diagram I posted will work on 6 volt negitive ground, it sure makes testing pretty easy,it worked great for me on my Farmall Cub with 6 volt positive ground.
thanks Jack
