EDNY Offline OP
Have the rear splash welded in and moving to the floor. Can someone with a 1933 Master 5 window coupe tell me what the "outside distance of the body panels are at the bottom of the center pillar"? Would also be helpful to know how far from the top you obtained the measurement
Need the measurement to ensure that the doors will be properly aligned (ie top and bottom)by spacing them apart accurately.
Ed
33Master5W
34Master3W
EDNY Offline OP
Looking at the hanging body, if I could even get the "inside" measurement between the two rear fender bottoms that would also work.
Both would be better..but I'll take what I can get! A PM works for me.
Ed
33Master5W
34Master3W
EDNY Offline OP
I'll even pay for the info!!! chevy
33Master5W
34Master3W
hello my 33 master 5 window coupe is 51 1/2 inches outside to out side and 40 1/8 from the top corner down with out the top door jamb trim hope that helps. Doc
EDNY Offline OP
Doc
Really appreciate the info, I have another member offering the fender distance also. With these two measurements I'll be able build a floor.
Thank you
33Master5W
34Master3W
