Posts: 382 |
Chevradioman or anyone else in the Pacific Northwest, Since your climate is similar to ours, this car has been kept in a controlled climate for as far back as known. We are going to buy a dehumidifier to put in the trailer. How important do you think it is to run AC/Heat to the new building? The garage is to be insulated but it is 1480 square feet and 16 feet to the eves so temperature control could be costly.
Hi George33Eagle, My building is very large also, however excess insulation was placed in the walls and ceiling. I do not air condition the building as it is not needed with that much insulation. I do provide electric heat with two units. I keep it at about 60 degrees in the winter. Best as I can tell the conditions that a car is kept in is not near as important as maintaining a constant environment in the enclosure.
